[xk] What size grub srew door handle XK140/ XK150
For the inner door handle of my xk150 I would like to know the
thread/ size of the grub screw.–
www.xks.nl
Try one of the grub screws from the three that hold the steering wheel
horn assy. in place.
Regards, Otto-----Original Message-----
To: xk xk@jag-lovers.org
Sent: Sat, Mar 30, 2013 3:12 am
Subject: [xk] What size grub srew door handle XK140/ XK150
www.xks.nl
In reply to a message from www.xks.nl sent Sat 30 Mar 2013:
The steering wheel grub srews are to big–
www.xks.nl
Unfortunately, it is not a simple screw shape. The thread OD is 0.093" and
the tip is unthreaded and 0.070 OD. Cheese head, slotted, of course. The
APPROXIMATE thread count is 60. I’ll let somebody else suggest what thread
family it belongs to.
I will send you a picture offline.
Gene McGough
XK-150 FHC S834515DN
XJ6C II 1976----- Original Message -----
Sent: Saturday, March 30, 2013 1:09 AM
www.xks.nl
Gene Mc;
Most likely a “BA” (British Association) thread. After our
company leaves, I’ll dig into my “Bolt Stuff” and look at my
various Thread Pitch sheets…
Charles #677556.
http://xktx.org.----- Original Message -----
and the tip is unthreaded and 0.070 OD. Cheese head, slotted, of course.
The APPROXIMATE thread count is 60. I’ll let somebody else suggest what
thread family it belongs to.
Gene McGough
XJ6C II 1976
In reply to a message from cb@XKTX.Org sent Sat 30 Mar 2013:
Sounds like it might be #8 BA, which is 59.1 threads per
inch or 23.25 threads in 10 mm, and 2.20 mm or .087 inch
diameter.–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
