Does anyone out there have the brackets that mount the cylinderical air
cleaner (hangs under carbs) or photos/measurements for same so I could make
some or a source for same?
XK 140 coupe
XK 140 coupe
David,
Sorry to be an opportunist, but can you advise what the two set-screws look
like that secure your door-lock striker to the shut-face pillar for your FHC
doors, and same question for any XK140 DHC owners please - but four
set-screws per striker.
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
David B Hammond
Sent: Tuesday, 13 January 2009 11:18 AM
To: xk@jag-lovers.org
Subject: [xk] xk 140 air cleaner
XK 140 coupe
David,
I can help you, if it is the same as on a 150. They are on a picture of a
batch I was about to powdercoat. I’ll send it offlist.
The pieces are still in a box, so I can take measurements tomorrow, unless
you stop me.
Gene McGough
XK-150 FHC S834515DN
XJ6C II 1976----- Original Message -----
make some or a source for same?David
XK 140 coupe
