In reply to a message from Harv XK 140 sent Fri 18 Dec 2015:
This is how it looks at my XK140:
Two 1/4 bolts at each side, looks like the rear holes have
been drilled after the adjustment has been finished.
The small 1/8 hole at your bonnet is probably drilled by
someone who wanted to keep the original position.–
sk99
In reply to a message from sk99 sent Sat 19 Dec 2015:
Thanks
My bonnet has a slotted hole on each side like yours, but I
don’t have the round hole in the bonnet. Now I am thinking
the small 1/8 inch hole on my assembly is a pilot hole that
should have been drilled thru and into the bonnet after the
bonnet was adjusted … and it got missed [forgotten] at the
factory??–
