To those interested, there is a meal following.
For those not interested, delete immediately.
About time for a wrap-up re the thread on HEADS that I have been pursuing -
there has been a huge amount of contribution both on XK-Lovers over past 10
years, but a lot more direct. There still remain outstanding questions and
some of my conclusions are NOT 100% conclusive by any means, but merely
reflect my opinions drawn from available evidence. I am aware that some of
my conclusions are at odds with long-held folklore, so make up your own
minds.
What follows is a SUMMARY only, but I do have an excel spread sheet where I
detail gathered numbers/sightings etc that on request, I am happy to forward
copies direct. These details will sanitize sources of information, as much
has been obtained on the understanding of privacy.
So although a wrap-up, please if anyone can add to the thread, or debate any
of my conclusions - I am 100% receptive, and note my specific outstanding
QUESTIONS at the end:-
A1. A-type: C2242. (First production XK cylinder head)
- identified by “XK774 C2242” cast on underside surface middle/inlet side
field. - quick identifier is not having studs for front end of cam covers, so a
so-called ‘studless head’ - casting by WILLIAM MILLS (WM) foundry, identified by spark plugs #2/#3 and
#4/#5 being paired within one Siamesed/oval spark-plug recess. - second casting by WEST YORKSHIRE FOUNDRY (WYF) not confirmed.
- only fitted to XK120s from start at Engine No. W1001 to approximately Dec
1950.(exact finish engine-numbers as per Spare Parts Catalogue J8)
A1a and A1b. A-type: C2242/1. (Supersedes C2242)
- this is the same casting as C2242 with only variation to justify the /1
being the machining of the recess for the seal at the rear of the camshaft,
with the same rear-seal machining variation made to the mating Cam Covers. - thus same “XK774 C2242” cast underside, and thus same “studless”
cam-covers.
a - casting by WM as above - with “Siamesed” spark-plug recesses.
b - casting by WYM now introduced, and identified by all six plugs, having
individual round recesses. - fitted from the first Mark VII saloon engine number A1001 > A7206 and also
XK120 from December 1950 to W4690. (exact start engine-numbers as per Spare
Parts Catalogue).
A2a and A2b. A-type: C.6733. (Supersedes C2242/1)
- quick identifier is now having three-studs added at front of each
cam-cover.
a - casting by WM identified by “C6733” over “B235” cast under head at
rear/inlet field.
b - casting by WYF identified by “C6733X” over “WM 351” under head at
middle/exhaust field. - fitted to XK120 from W4691 to last F4250 including all to SE specification
with engine number stamped -8S (and Mark VII from A7207 >) and also to
“standard” XK140 from G1001 to G6911 (and all Mark VIIM to > N3657, and
first 2.4 litre saloon BB1001 to BB1152)
(AND yes - I contend NO XK120SE fitted with -8S engine number heads are
anything other than C6733 A-type heads - none are C-type)
A3a and maybe A3b. A-type: C6733/1. (Supersedes C6733)
- no quick identifier from C6733 as the /1 is a result of the casting being
slightly modified to protect the exhaust-manifold threaded stud holes
breaking into the water-jacket, so not visible at all with exhaust studs
fitted.
a - casting by WYF identified by “C6733-1” over “B235” under head at
middle/exhaust.
b - casting by WM not yet identified/seen. - fitted to “standard” XK140 G6912 > G9980 (last); Mark VIIM N3658 to N5xxx
(last) and 2.4 litre (BB1153 to last ).
C1. C-type: C6257. (First C-type head)
- not yet physically identified, but C6257 is part number shown in C-type
Spare Parts Catalogue. - first used mid 1951 thus suspected to be either a modified C.6733 casting
or a semi-completed C6257 casting , but detail of any marking unknown, so
may evolve across both castings. - foundry unknown, but guess WYF only.
- claimed that all can be identified by Head-Sequence-Number Q2xx stamped at
rear of spark-plug valley. - fitted to all XK120.C (C Type) engines E1001 to E1058, and although SB95A
of April 1953 suggests limited availability as an after-market spare-part
Assy SD.1025, any so fitted to modify XK120 or Mark VII is likely to be
minimal and limited to a handful of fully race prepared “works” and favoured
“privateer” cars.
C2. C-type: C7700. (Supersedes C6257 but not for production supply)
- listed in J12 Price List of May 1953, but so far only one example
seen/pictured. - identified by “C7700” over “C2” cast on the underside middle/exhaust
field, thus presumed to be WYF casting. - unknown when first used, so possibly on some late build XK120.C to E1058,
and also possibly as part of Assy SD.1025, but also possibly as core for
modification to D Type specification/use.
C3a and C3b. C-type: C7707. (Supersedes C6257 for production supply)
- listed in J12 Price List of May 1953, but actual production supply not in
place until Oct 1954 for XK140MC )
a - casting by WYF identified by “C7707” over “C3” cast on the underside
middle/exhaust field, and a RHxxx sequence-number on front/inlet field. No
cast ‘C’ in spark-plug valley.
b - casting presumed WM but unverified. Identified by “C7707” by itself
cast on the underside middle/inlet field. No cast ‘C’ in spark-plug valley. - unknown when first used, so possibly on some late build XK120.C to E1058,
and also possibly as part of Assy SD.1025, but also as core casting for
modification/build to D Type specification/use. - used on early build XK140MC from G1001 to about G1500, but up to Head
Sequence-Number AUxxx stamped at rear of spark-plug valley, and very rarely
to Mark VII. - limited availability as a Spare-Part assembly for replacement or for XK120
for modification/upgrade purposes
C3c and C3d. C-type: C7707. (Supersedes C3a and C3b for production
supply)
- now quickly identified by addition of a large cast ‘C’ between Spark Plug
#3 and central core-plug on spark-plug valley.
c - casting by WYF identified by “C7707” over “C3” with a RHAxxx
sequence-number adjacent, on the underside middle/exhaust field.
d - casting by WM unverified but possibly also made. - used on later build XK140MC from after about G1500, but after Head
Sequence-Number AVxxx stamped at rear of spark-plug valley, and very rarely
to Mark VIIM. - limited availability as a Spare-Part assembly for replacement or for XK120
for modification/upgrade purposes.
C4 C-type: C7707/1. (Supersedes C3c and C3d for production supply)
- no quick identifier from C7707 as the /1 is a result of the casting being
fitted. - casting by WYF identified by “C7707-1” over “C3” with a RHCxxx sequence
number adjacent under head at middle/exhaust. - casting by WM not yet identified/seen.
- fitted to XK140MC G6407 > G9980 (last) and very rarely to Mark VIIM Nxxxx.
D1a and D1b. D-type: C7896. (These are modified/upgraded C-type)
- identified by C.7707 cast underneath with all numbers ground of and “7896”
over stamped.
a - based on C3a casting, thus no cast ‘C’ in spark-plug valley. - it would appear that many C7896 heads have Head Sequence Numbers from
AYxxx sequence, but not all, and most AYxxx Sequence Number heads will NOT
be C7896.
b - it is possible that there may be some C7896 heads based on C3b castings
but at this stage thought unlikely. - it is improbable that any C7896 heads will be based on C3c or C3d or C4
castings, thus will NOT have cast ‘C’ in spark-plug valley.
Other than that - that’s the end of both A-type and C-type Heads.
This thread is not considering later type ‘XK’ Heads, including “Wide-Angle”
D-type Heads, B-type heads as fitted to XK150, Mark VIII and 3.4 litre
saloons, nor “Straight-Port-Heads” as fitted to XK150’S’, nor experimental
heads, 4-cylinder heads nor any other prototype heads.
My main questions are:-
Q1. Details/photos of the C6527 head - C1 above.
Q2. Further evidence of the AUxxx / AVxxx demarcation between - C3a/b and
C3c/d.
Q3. Any more examples of C2.
Q4. Is there a WYF version of A1
Q5. Is there an A3b WM foundry casting.
Q6. Any comments - preferably supported by evidence of anything that
disagrees/contradicts my Summary above.
AS before - there is a LOT of work and effort in putting this together, with
fantastic contribution by many on XK-Lovers - some on-list, but a huge
amount direct off-list.
So I am more than happy to share my data sheet - albeit sanitised re sources
of information.
Print this off guys as its not a 5 minute read, let alone preparing any
responses to my Q1 to Q6.
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.
