PS.
SB.95A not just SB.95 as I have shown.
Roger Payne
XK140MC OTS; 4.2E OTS; DaimlerSV8
Canberra, Australia
.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Roger Payne
Sent: 15 August, 2016 11:40
To: xk@jag-lovers.org
Subject: RE: [xk] XK120 C Type head
Karl,
That’s the problem 60 years later, locating hard proof to support the period
THEORY, as its impossible to DISPROOVE something.
After years of effort from three continents, I have pretty well concluded
that the ‘infamous’ SERVICE BULLETIN No.95 is a ‘red herring’
Whether floated by Jaguar for ‘homologation’ reasons for their factory
in-house and works supported private teams, I really do not believe any
XK120 owners outside factory prepared cars, or maybe one or two of the UK
based factory supported teams (like Ecurie Ecosse) ever received all or
parts of this SB.95 kit. Clearly however owners of C-types, may well have
sought/sourced spare heads (as a priority supply from Jaguar), and who is to
say such heads or ex-C-type heads didn’t end up being fitted to USA racing
XK120s. Be worth tracking down the top USA racing XK120 teams/cars from
1952 to 1954 period (if they survive in their 1954 status).
But I am equally conclusive that no XK120 EVER left the factory originally
equipped with a C-type head and/or H8 carburetters.
I have ONE only claim that I have been unable to verify one way or the other
remaining, which has some probability of possibly being true, and that is of
a USA Customer for a 1954 XK120 FHC demanding/insisting his new XK120 FHC
order to include C-type head and H8 carburetters, that on being told not
possible by Dealer, then direct to JCars USA, ended up approaching Jaguar UK
direct and insisted, and some nine months later, received his new 1954 XK120
FHC so fitted, one would presume off-line, by the factory experimental
department.
It’s a good story and rings as a true possibility, but if so, does tell you
that short of similar effort, there would not have been a second XK120 so
factory-new delivered.
More probably, as you recall - parts supplied in the boot for the dealer to
fit, but in such a case, that’s still not factory original, as who is to say
what a local dealer may or may not have done, indeed fitting a brass-plaque
to the firewall amongst other local USA mods. Maybe your story relates to
my remaining claim?
So best I can tell is during the 1952 to 1954 period Jaguar evolved their
standard A-type head by machining variations and a couple casting variations
into first the head fitted onto production C-types, thus getting the name of
C-type head, and thus SB.95 for homologation purposes for the odd factory
supported XK120/Mark VII.
But clearly for production purposes Jaguar did tool-up to make C-type heads
that were offered as part of the XK140MC options kit, invariably with normal
H6 carburetters and manifold and distributor.
The first of these ‘production’ C-type heads did not have the raised-cast
‘C’ on the spark plug valley, that being added in early 1955 (I have rough
demarcation point).
The XK120M (USA terminology), or factory terminology XK120 SE (Special
Equipment) did not have a C-type head, but indeed the same normal XK120
A-type head, but with high-lift cams and valves fitted to provide the 20 bhp
power increase claimed. With their Engine numbers stamped -8S, many people
confuse this with XK140s where -8S indicates a C-type head being fitted.
But there are several physical indicators on both A-type and C-type heads,
and indeed the experimental/evolving 1952 to 1954 development heads that any
claims of having an original C-type head fitted is very easily proved, or in
the case of XK120s easily disproved.
And same thing applies to associated Inlet Manifolds and H8 carburetters.
AS above, easy to PROOVE something, but unfortunately impossible to
DISPROOVE something, especially 60 years later, but at this stage I am 100%
happy with my conclusions, but still quite happy to be PROVEN wrong.
Roger Payne
Canberra, Australia
karl
Sent: 15 August, 2016 01:43
Subject: Re: [xk] XK120 C Type head
In reply to a message from Nick53XK120S sent Sun 14 Aug 2016:
I was told about 35 years ago by a person in SCal who sold lots of used
special equipment parts and seemed to know XK120s pretty well that he had
personally seen a C Type head received in the boot of a new late xk120 for
installation by the dealer before delivery as new. He did not specify
whether this head was stamped with the proper engine number or not.
I have often wondered whether it was likely or not pre- stamped.
He also claimed that a particular Jaguar dealer actually had made up locally
a brass plaque that the dealer attached to the firewall of new cars to
document the fitting of a true C-Type head.
I pass this along as unproven second -hand information
I did buy from him a genuine auxiliary fuel tank and a set of original
bucket seats, and perhaps some other stuff as well. I say that only to show
that he had some knowledge of, and interest in special equipment.
Karl
during the late XK120 mfg…then have no engine number on the inner
front flat…as it would not have been '‘attached’ to a car?
karl
–Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]-- --Support
Jag-lovers - Donate at http://www.jag-lovers.org/donate04.php –
