Inspired by recent posts on xk120 grommets, I decided to
compile a fairly comprehensive list of grommets for the XK120.
This research is based on:
- xk120 Anatomy books
- Original Jaguar XK Porter book
- Bill Bassets grommet list
- Autosparks grommet list
- Lucas Equipment Specifications and spare parts master
catalogue - my xk120 OTS Dec '53
Please note:
- Dimensions specified by grommet part numbers are grommet
dimensions - OD dimension specified at grommet location is the sheet metal
hole in my xk120 - GR## or R## signifies Bassets PN
- PN# signifies Jaguar PN
- Lucas: ### signifies Lucas PN
- AS: ### signifies Autosparks PN
- Grommet shape:
o SB � ‘‘Semi Blind’’ Centre grommet
o D � Donut shaped grommet
o FD � �flat� donut shaped (Internal diameter at right
angle, outside round)
o S - Special
GROMMET D PN# C.2784?, Lucas:199001 GR18
- 1 License plate lamp grommet OD=10mm
- 1 on top of license plate panel for wiring. OD=11.5mm
GROMMET D PN# C.974, Lucas:858062, AS:C551, GR1 � OD: 1/2�
- 2 in frame for reverse light switch, OD=18mm
- 1 in trunk Iid for reverse and license light harness,
OD=16mm - 2 in frame bracket for fuel pump mounting. OD??mm
- 2 for windshield washer water tube through the cowl,
near the demister mounts. OD=12.5mm
GROMMET D PN# C.975 Lucas: 858063, AS:C552, GR2 - OD: 3/4�
- 1 for Fuel pump wire outside of frame, below firewall.
OD=18mm - 1 in Side Frame under Scuttle structure for radio unit
(OPIONAL, to be verified)
GROMMET D PN# C.976 Lucas:???, AS:C553, GR3 - OD: 1� ID:3/4�
- 3 for windshield wiper rack cable thru inner cowl
bracing. OD=25mm - 2 for fog lights under the front wing air intake
GROMMET D PN# C.977 Lucas:???, AS:C554?, GR4 - OD: 1 1/4� ID:1�
- 2 for Forward fender valance on LH side of car for head
light bucket and turn/side light wire connection OD=28mm - 2 for rear bumper studs through body (NB: Parts Manual
also indicates C.2869)
GROMMET D PN# C.1426, Lucas??, AS:C555, GR6 � OD: 1 1/2� ID:1
1/4�
- 4 in frame holes for fuel and brake lines OD=37mm
- 3 inside cowl bracing for cowl harness, OD=37mm
GROMMET D PN# C.3766/1
- 1 Steering column grommet OD=64mm (OTS only)
GROMMET FD PN# C.1042 AS:C522?, GR5 - OD: 5/16� ID:7/32�
- Heater fan feed wire in cowl bracing OD=8mm
GROMMET FD PN# BD.3210 AS:C527, GR21 � OD=1/2� ID:5/16�
- 1 in fuel filler compartment for vent tube. OD=12.7mm
GROMMET FD GR13 - 1 in firewall for windshield wiper rack cable. OD=15mm
(possibly a D type grommet?) - 1 fuel filler compartment drain pipe going through
inner wing OD=approx. 15mm (not sure if originally there…)
GROMMET FD GR19
- 1 oval grommet for windshield wiper rack housing in
cowl bracing. OD: 47mm
continued on next post…–
ysmalkie
