For today’s research archaeology lesson we turn to the
registration plate panel on the boot lid. There will be a
test at the end of class.
I think the only thing worse than repairing damage caused by
the Dreaded Previous Owner must be repairing damage caused
by the Damoclesian Present Owner.
Some time ago I dropped a ladder on my boot lid and made a
dent. This weekend I thought I would take the boot lid off
and see if I could bump it out.
Mine is a Nov '51 FHC originally pastel green metallic with
black in the boot. Some OCD DPO got a little crazy with his
obsession to cover all the green with red paint, and he shot
over most of the black. I wanted to see where it should be
black and where it should be body color. I was surprised to
discover the original black was all over the inside of the
wood framing, even where it was covered by the rexine panel.
But in the triangular hinge plate contact areas there was no
paint of any kind whatsoever, except a hint of green residue
as if from paint thinner on bare clean steel. So the black
was sprayed on after the bootlid was attached to the body.
The long curved side pieces of the wood framing are
laminated, I guess for strength, and probably cheaper than
steam bending.
I also found 9 lumpy aluminum weld blobs and 2 bondo worms.
The bondo worms appear to be filling holes left by some
dealer’s badge or something. Four of the welds are in a 10’’
x 20’’ pattern and most likely plugging holes left over from
a luggage rack long since removed, and one looks like a
mistake, the luggage rack installer drilled right next to
the center wood brace.
The other four welds are the subject of my question. They
are in the number panel area and in a pattern 4.25’’ x 15’’
(108mm x 381mm). The number panel is held on by 4 screws in
a 4.25’’ x 12.5’’ (108mm x 318mm) pattern.
I see in the parts catalogues there are 4 part numbers for
number panels for the steel cars and 2 different part
numbers for the alloys. I understand about USA/CDN having a
different size license plate and hole pattern than
UK/European plates. But is the mounting of the panel
different? I can see it is on alloy cars as they have screw
heads visible on the outside. What about steel cars? Why are
there alternate part numbers and what is the difference?
It appears my car was originally drilled for a different
panel. The question for the class is which one? Who welded
it and why, since the unused holes would have been covered
by the panel?–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
