In reply to a message from marcelxke sent Thu 28 Jul 2005:
Marcel
Perhaps you should ease up on the gas a bit ;-)–
S836006DN FHC, S830747 OTS, GCJ17 RR 20/25
Calgary, Alberta, Canada
Hello: Marcel:
Well I see you have the 150 running>>lots of luck
Make sure the 2 fuel pumps are well grounded separate to the chassis
other than that I would suspect that the one pump coil is shorted out, take
care of it soon !!!
Have fun
Manny
Marcel If pump is getting hot theres something wrong They will run for
hours continious on the bench pumping kerosene and barely get warm CAUTION
disconnect power from pump it will run on one ok Remember one flash and its
all ash regards Terry----- Original Message -----
To: xk@jag-lovers.org
Sent: Thursday, July 28, 2005 9:38 PM
Subject: Re: [xk] XK150S fuel pump running hot
Hello: Marcel:
take
care of it soon !!!
Have fun
Manny
