XK120 front muffler frame bracket
Hi, does anyone have a picture of the bracket that should be here…perhaps dimensions so that I can fabricate one?
Thanks Per1
0FC12EDA-92BE-41CC-8F43-44155A1B38CD
Per,
There is a bracket welded to the chassis, consisting of two parts. One is attached to the top of the chassis rails and the other coming from the bottom. They meet in the middle with a horizontal section through which a bolt is placed to held the silencer bracket and a rubber pad.
See picture below.
See also the original Jaguar drawing of the chassis at this point.
There may be variations for the bracket, whether you have a single pipe or twin pipe exhaust, but that can all be solved.
Thanks a lot Bob, very informative.
Per
Hi Per
In the following thread you will find some very useful Informations too:
Best Regards
Lukas
…I had the same problem as you have :wink:
…from entry #39 on…
View from the bottom.
View from the top.
Many thanks to you all , it is on its way
Then it is the rear muffler bracket and tailpipe…does anyone have the measures of the brackets parts number 479123 and 258185 , they too seem to be easily made form flat steel
Per
This is C.3648
This is C.5062 and C.5838
If you have a Twin Pipe exhaust system, the rear suspension of the silencer is slightly different, but still using using Bracket C.3648 as shown by Rob R. See example below:
Thanks a lot for your contributions , here is the end result:cid:35830EB2-2B6D-4A42-860C-25B1A23E7245
cid:6CE6036F-E143-4623-A663-DC471D66672D
cid:DEC37D75-91CC-4E72-8087-533B5CC150CE
