I’m in an exceedingly tough spot here. I have several days’ worth of time trying to remove my inlet manifold and, it’s just not happening. I’m speculating that this car may have spent no small amount of time parked down at a local marina in days gone by. Or at the least, a gasket that weeped moisture. How else to explain fully half of the studs being well and truly bonded along the lengths of their shanks by rust and corrosion? Here’s my succession of removal attempts:
Saturated all studs with PB Blaster for a few days. Then I double nutted the studs and was able to remove almost half of the 18 studs.
Where double nutting wasn’t good enough, I then welded the nuts to the studs. That worked for one or two. The others just sheared off.
I profiled the remaining studs flush with their bosses. Then I center punched all studs and drilled all 5/16" studs out to 1/4" inside diameter to within 1/2" of the manifold/ cylinder head joint. My thinking was as this leaves so little substantive “meat” left in the shanks, surely with some more penetrating oil and chisels (!!!) used as wedges (not at the joint face though) it would have to pop off by now. Nope. Not even the barest hint of a gap starting.
What to do, what to do as my options are greatly winding down.
Some background:
I just wanted to remove this along with the carbs, water pump, generator, flywheel, etc. so as to leave a basic long block I can then take to a rebuilders prior to a thorough internal going over. It last ran in '82. If I take it over in its as-is condition now I’m going to feel a sense of shame as I, too, have a machinist’s background.
So now I’m researching chemical options:
I’ve seen on the 'net that alum (potassium aluminum sulfate) as sold in some grocery stores for home pickling along with water is supposed to actually eat the studs but leave the surrounding aluminum intact. Other posters all say that the solution must be kept heated to almost boiling otherwise the solution will want to re-crystalize.
Muriatic acid? Seems too corrosive and how do you dilute it down while still maintaining its effectiveness?
Sulfuric (battery) acid? We’ve seen what it does to steel in all manner of battery compartments but I don’t want it to ruin the aluminum as well.
Phosphoric acid? Some say it will only go so far before passivating the metal studs where the reaction then comes to a stop.
Finally, I know having a shop with an EDM (electrical discharge machine) can possibly electrically erode away the studs but I think that could get pricey. Plus, having the head and block together means I can’t exactly toss this in the back of my car at present. I also don’t want to do anymore disassembly at this point. In a worse case scenario – and lacking other options I’m not aware of – I’d have to destroy the manifold in order to remove it and replace it with a used one from… somewhere. I’m loathe to even write those words as its admitting that I will have failed. Ugh. As an aside, I also researched the marine-related forums such as the wooden boat restoration ones and came up empty as well.
Moderators: feel free to move this to the engine forum if it would be a better fit there. Thanks.
Comments on your part are welcome.
Chris
