Piece of welding rod bent to give you the overall length and shape Nick,
then some 5/16"rod threaded each end, weld on a washer (i use two nuts each end)
And Bobs you Auntie ! 200 bucks Whaaaa ! sounds Deer.
Peter B
the picture shown is not an accurate copy of the part, the threaded end without washer is much shorter both in the unthreaded area and the thread
price is ridiculous $20.00 item made as one ofs and $5.00 item made by the 100
Thank you, Simon. A much better representation than what appears above. Is the offset between the two bends about 90 degrees?
$30/pair is more like it should be, Jim. Some of the spares pricing I’m encountering while in this final stage of the restoration is eye-watering. While we should be grateful we can still find parts for 65+ year old cars that gratitude shouldn’t be subject to a 600% markup.
Nick, you don’t want to know how much I had to pay for a pair of these, which were horribly rusted, dented, with badly welded repairs and only just useable as patterns. Original 1964 AC Cobra 289…
I make the overall length to be 13-1/2", with one end threaded 5/16-22 BSF x 1/2" long with a flat washer welded where the thread stops, and the other end threaded 5/16-22 BSF x 1" long with double nuts where it is attached to the chassis bracket. This is a FHC so it may be different from the OTS.
That measurement provides the finishing detail, thanks Rob.
This generous XK subset of JL is a wonderful resource.
I have a set of BSF (and BSW) taps and dies and a handful of spare 5/16-22 nuts so may just cut the threads to original spec, just for chuckles, though that level of dedication to originality detail on parts tucked under the car that nobody can distinguish from UNF might be considered just a bit over the top .
Iv’e cut mine BSF Nick, being the stickler to originality that I am, or was it that the BSF die was top of the pile?
anyway , !
Of course a judge will know when he / she applies a 1/2” AF spanner instead of the correct 5/16 BSF or is it 3/8 Whit?
Peter B.
