XK120 Sump Rear Tray with Baffle
I cleaned up the baffle tray that sits in the bottom of the sump at the rear, screwed down by four 5/16-18 UNC X 1/2" hex head screws.
I’m not sure if this is C.2392 for the flat bottom sump, or C.2392/1 for the stepped bottom sump.
I noticed it has 6 spot welds across the center, holding nothing.
I suspect there was a baffle plate in there, which has gone awol.
By the oil marks it looks like it was there for awhile before departing.
I also suspect the purpose was to limit the oil sloshing around in the chamber where the oil level pickup floats.
Urs Schmid Vol. 1 shows one on page 69.
I’m wondering if the baffle was removed because it was made for a flat bottom sump and therefore was too deep?
Anyone have a picture of one of these?
Rob,
I had the same problem: the aluminium baffle plate C.2342/1 (spot-welded to the tray) had apparently separated from the tray and taken out by a PO. “Happens all the time”.
I made a new baffle and used pop-rivets this time to fit the baffle. Note the cut-outs at the bottom for the ribs of the sump. I even stamped the number on the baffle (just for fun). I then could screw the complete assembly in the sump.
Thanks Bob. That’s weird; the spot welding must have been poor and/or the sloshing of the oil is more violent than I would have expected.
This picture shows it much deeper, item 95, so it may be the earlier version, though the picture shows the stepped sump.
I see you have the same dipstick marks around the dipstick clearance hole that I have; not quite enough clearance there. Well I guess it shows that somebody checked the level quite often. Or they failed to get it in all the way and it rattled around in there for awhile :grin:
You can pretty much expect that in an XK120. Spot welds in the roadster aluminum door construction can be poor as well. Aluminum rivets looks like a sensible solution.
I don’t think I have ever seen spot welds on anything aluminum in the modern era.
Mike,
Would like to disagree with you on that: many modern aluminium car bodies are spot-welded nowadays, often called Resistance Spot Welding (RSW) with very sophisticated equipment like water cooled copper electrodes.
In recent years, research work by aluminum sheet suppliers and automotive companies has overcome many of the original problems with RSW of various types of aluminum alloy sheet, so that today it is used in production of various automotive vehicles. For example, GM has introduced its patented multi-ring electrode design for use in the RSW of closure panels on various high volume production vehicles.
You can even buy Aluminum spot welding equipment for the DIY segment.
This is why you never throw out old parts. I found another one in a cracked sump.
The baffle piece is definitely spot welded to the main tray.
Quite a lot of burned oil on there. That’s as clean as I could get it with gasoline, a brush and a rag.
Here’s the one in the flat bottom sump. It looks deeper.
20230911_064807
It is possible to join aluminum sheet metal with a standard spot welder - I’ve done it several times. First you clean the surfaces to be spot welded with a stainless steel brush. Then rather than attempt to spot weld the two sheets of aluminum directly you need only sandwich them between two additional strips of 20 ga steel before clamping the 4-layer sandwich in the welder and pulling the trigger. Works a charm.
another question part 90 the oil pick up pan goes into oil pump and is held in with split pin is there an O ring on this pipe where it goes into oil pump? terry
No, it is just a close but swiveling fit. An o-ring would prevent it from swiveling freely.
