Nice to see a current thread on this topic, I’ve been reading thru a lot of very old comments from historic threads. Certainly the emotions don’t change, but the experience has presumably!
My car is not for show, or really that much go! Folks who point out tires that have “only " speed ratings of 80 mph, good on you! I’m not likely to drive too much over 80 kph… in Canada eh.
And my budget is tight…
I’ve been spending too much time on the tiresize.com website where you can type in any tire size and see all the size specifications…
It looked like some 195 tires would be the closest size match to the original tires, but the selection is very limited, and all the tires I found were intended for delivery vans, so they would be very firm and noisy.
I’m now aiming for the Continental Contiprocontact in 215/70 R16. This is a sport car tire unlike many other in this size that are designed for SUVs.
An important thing I discovered along the way is the size data presented is related to the width of the rim that the tire is being mounted on… so for example this tire shows as having an 8.3” width, but that is based on a 6.5" rim. For each .5" change in rim width you get 2/10" change in tire width… so mounting these on a 5.5" rim brings the width down to 7.9", much closer to the 7.5" i believe the original tire would be… or so I believe from my readings…?!
The 205s that others have been using seem to be a reasonable amount larger diameter at 28.3" vs 27.7 of the originals or 27.9 of these 215s…I’d be worried about the larger diameter on the 205s, but other folks seem to be running them without problems…
Maybe over thinking the whole thing…
Any reasons not to buy these 215/70 R16 Continentals?
Cheers,
