Not sure if I’m encountering a problem or just normal behavior!
I’m doing a brake inspection plus clean and adjust on my XK140, she sat for @ 2 or 3 years before coming to my garage…
Started with the right rear… undid hand-brake, removed knock-off wheel and brake cover, removed brake shoes, cleaned everything, ensured adjuster works properly and freely and that cylinder slides freely in the back plate slot. Reassembled… and this is where the mystery comes in…
Before disassembly there was some “drag” when rotating the wheel (Car on stands, trany in neutral, handbrake off), thought it was likely sticking adjuster etc due to age and build up of dirt, hence the strip, clean, rebuild. But after reassembly, with the brake pads at minimum adjustment ie way away fro the drum, there is still a lot of drag when turning the wheel by hand… definitely not “spinning” it to center the pads etc. I assume at this point that the drag is coming from either the bearings or the rear axle… there is no apparent noise, no slop or freeplay… maybe this is normal tension from the differential?
Thoughts appreciated!
