[xk8] ABS Fail Light
The ABS fail light has illuminated on my 98 XK8. I am also getting
a message in the message display that the ASC is not functioning,
which I assume is related to the ABS fail. Anyone know what causes
this and what might be the problem?–
Dave M 98 XK8
could be a variety of things, from a sensor or connector to the ABC ECU…
it happened twice on the XJR, one was minor (forgot what) the second time
last month was a defective ABS ecu, thankfully under waranty!
is it intermittent ? after you shut down the car, does it come back rigth
away?
Pascal----- Original Message -----
To: xk8@jag-lovers.org
Sent: Saturday, April 12, 2003 1:06 AM
Subject: [xk8] ABS Fail Light
Dave M 98 XK8
In reply to a message from Pascal Gademer sent Sat 12 Apr 2003:
during an emissions test my abs light came on and it did not go
off. Once I drove a quarter mile it reset. I have never had a
problem with the slip control light coming on.–
Jeff 98 Coupe
Wilmette/Illinois, United States
