[xk8] additional power outlets (cigar lighter)
Has anyone had experience with adding additional cigar lighter
power outlets to an XK8? The one that is standard is not in the
best place nor does it allow for phones, navigation devices and i-
pod type equipment to be used at one time.
Thanks–
Al1
In reply to a message from Al1 sent Thu 13 Jul 2006:
There is an additional power connection specialy fitted for
adding a second power outlet. It is hidden behind the glove
box inner compatment, on the rear external side. You’ll have
to remove the glove box, but be careful not to touch the
wrong screws when doing so: some of them are there to adjust
so the cover closes neatly. Refer to the JTIS.
Usually the relevant fuse is not fitted, so you’ll have to
add it.
There is another connection, easier to access, next to the
battery; it’s also possible quite easely to route a cable
from there to the central armrest for instance (maybe even
the better choice to go to the armrest).
But if it is only a question of number, there are also
three in one adapters.–
Charles_3000
