If you own an XK8 convertible there is a potential big problem that
could be disastrous, but there is a simple fix:
The problem: With the top down and the vinyl cover in place, the
two metal snaps that hold the front of the cover down wear out,
loosen over time and lose their holding power. At highway speeds
over 50mph, the vinyl cover takes on a lot of air pressure and the
cover wants to lift off (check your rear view mirror some time at
about 60 mph). If the snaps let go the cover will blow back staying
attached at the trunk with the two metal snaps acting as a steel
studded whip, flogging the rear deck and damaging paint and
possibly metal as the cover flails itself against the trunk lid
before you will be able to stop.
The simple fix: I attached two 3/4� x 3� Velcro strips to the flap
that tucks behind the rear seat. There is carpeting on the seat
back just below the headrests so when the flap is tucked in the
Velcro secures itself to the carpeting providing far more holding
power than the snaps, which now become only secondary hold downs. I
placed the two strips along the bottom edge of the flap, just above
the hem, and at the 1/3 and 2/3rds distance along its length. I
actually sewed them in place using a needle and cord like thread
from the leather trade. Don�t trust adhesive backed Velcro as it
will not stay attached to the slick vinyl.
Check your metal snaps today before your next highway drive. If
they do not feel secure enough or easily unsnap with little
resistance, consider making this simple repair.–
Steve Hannes – 02 XK8 - 96 VDP - 02 X-Type
Phoenix, AZ, United States
