After renewing the hydraulic hoses. how do we bleed the air out . the pump seems to barely run…?
Close the valve on the pump and hang the lines out the left door into a drain pan. Operate the pump with the top switch until fluid flows. Attach the lines to the hydraulic cylinder and reassemble.
Ensure that the reservoir is topped up.
bob
THX…will give this a shot today…
Hi Bob, do you have a ph # I could speak to you on…the subject… mine is 604 465 7244… in BC…
