Good evening, this is my first post. I have a rear window that goes
up but stops with about 3/8’’ to go. Does anyone have an idea on how
to bring it up all the way?–
jim 1999 XK8
Carmel, IN, United States
In reply to a message from Jim Lav sent Mon 26 Aug 2013:
Often the front window gets a bit out of alignment and interferes.
If not, there are also rear window adjustments. If none of this
works, there is excessive stretch in the regualtor cable or a bad
bushing in the regulator and the regualtor can be replaced or
professionally rebuilt.
In reply to a message from WhiteXKR sent Mon 26 Aug 2013:
Thank you your research is impressive and the solution is nicely
laid out. I really appreciate the help.–
jim 1999 XK8
Dana=============
jim 1999 XK8
