I picked up my 1997 XK8 from Jaguar after they replaced the upper
control arm bushings. When I got in the car I noticed that the
power driver seat was no longer working. Thinking it was a fuse
issue, I returned home and replaced the fuse. Of course replacing
the fuse didn’t work. If I remove the fuse, wait 5 seconds, and
replace the fuse, the power driver seat will work for about 10
seconds. After 10 seconds it ceases to work until, I again remove
the fuse and repeat the process. I’m assuming it’s a ground
problem. Here are my questions, if it is a ground problem, could
it be related to the replacement of hte control arm bushings?
Second, any advice on what I should do? I would prefer not to
bring the car back - especially since this car has been looked at
by Jaguar 4 times over the past 3 weeks for the same related
suspension issue.
Vincent
2000 XKR
2000 XJR
1997 XK8
1997 RR 4.6 HSE–
Vincent Eng
Potomac Falls, VA, United States
