June 2002 XK8 Coupe - Still getting that horrible clonk on power
on/power off at low speeds in traffic and now the dealer is getting
a ‘‘Jaguar Engineer’’ to take a test drive, but they tell me that
there is always a noise from the differential when ‘‘blipping’’ the
gas pedal. I am also told that even if they replaced the diff
there would be no difference. Cannot believe it!!! the noise and
vibration is so pronounced there must be wear and/or a fault that
they are aware of and anticipate. I cannot but help feel they are
aware of a design fault and trying to fob me off with ‘‘that’s just
normal’’. Anyone else out there noticed this sort of trouble??
Appreciate any assist here…
Steve–
Angus’s Dad
Nottingham, United Kingdom
In reply to a message from Angus’s Dad sent Mon 12 Jun 2006:
dealer sounds bogus. only clonk I get from the diff is when I change from drive to reverse then I get a clonk as the vehicle starts to reverse. Feels similar to a worn UJ on the prop that I used to get on my xj6’s but I dont think the xk8 has Uj’s does it?
Alan
99 xk8–
Are you sure it’s not from the gearbox? If I recall
correctly it’s usually on the 2nd gear that you get the
clonk until the drive goes completely.–
