On my 1997 XK8, I had this P0441 code because of a disconnected vacuum
line on the evaporative system.
I don’t know the typical fix, or even if my failure was a more or less
common type of failure. Mine happened because the dealer left the hose
disconnected after replacing my intake manifold.-----Original Message-----
From: owner-xk8@jag-lovers.org [mailto:owner-xk8@jag-lovers.org] On
Behalf Of dmondeel
Sent: Friday, May 20, 2005 9:26 AM
To: xk8@jag-lovers.org
Subject: [xk8] DTC code P0441
DTC: P0441
Fault Description:
EVAP system incorrect purge flow
Possible Causes:
EVAPP to ECM drive circuit open circuit.
EVAPP power supply circuit open circuit
EVAPP to engine purge pipe damaged/blocked/leaking
EVAPP operation vacuum hose leak/blockage
EVAPP failure
Make sure the gas cap is on tight. Then clear the code out and see if it comes back. I get P0445 about once a month. I clear it out and it goes away for a while and then seems to come on at complete random. I have heard a few others mention that the gas cap not being on tight enough can cuase these faults.
Jason
97 XK8-----Original Message-----
Sent: May 20, 2005 8:25 AM
DTC: P0441
Fault Description:
Possible Causes:
EVAPP failure
In reply to a message from dmondeel sent Fri 20 May 2005:
I must have inadvertently disconnected the purge line from the
purge valve when moving it out of the way while replacing the
secondary timing chain tensioners. Clearing the code, reattaching
the hose fixed the problem.
-Dave–
DTC: P0441
dmondeel
