Sounds like you need to do the window reset procedure.
With the doors closed and the key on, raise both windows (at once, or
one at a time, doesn’t matter) until you hear a click or two.
Next, lower both windows until you hear a click or two. This resets the
upper and lower limits of the windows.
Now, if the problem comes back, it often is due to a weak or bad
battery.
And, welcome to the forum!-----Original Message-----
From: owner-xk8@jag-lovers.org [mailto:owner-xk8@jag-lovers.org] On
Behalf Of mikegatto
Sent: Monday, September 24, 2007 6:35 PM
To: xk8@jag-lovers.org
Subject: [xk8] HELP! Automatic Window Feature Upon Touching Door Handle
I just bought a 2001 XK8 and love it.
Unfortunately, there is a minor problem.
The passenger window lowers a fraction of an inch upon lifting the
handle to open the door. It is supposed to raise after the door is
closed. It doesn’t.
As a matter of fact, if one opens the door AGAIN, it lowers the
window another fraction. And doesn’t raise it.
It is almost as if it senses the window is all the way to the top
already. But I don’t know.
Any ideas?
MANY thanks.
mikegatto
Visit the Jag Lovers homepage at http://www.jag-lovers.org for exciting
services and resources including Photo Albums, Event Diary / Calendar,
On Line Books and more !
