In reply to a message from Brian Mellor sent Thu 3 Aug 2006:
Brian, are you sure of your VIN numbers? I have different figures:
Here’s what I have:.----------------------------------------------------
Service action S514 was issued to UK dealers in May 2004:-
Model: XK Series N/A vehicles
Model Year: 1997 to 1998
VIN Range: 001036 to 031302
Model: XK Series SC vehicles
Model Year: 1998.75 to 1999
VIN Range: 024695 to 042775
Model: V8 XJ Series N/A vehicles
Model Year: 1998
VIN Range: 812256 to 853935
Model: V8 XJ Series SC vehicles
Model Year: 1998 to 1999
VIN Range: 812256 to 878717
Dear Colleagues
A concern has been identified with the throttle operation on a
number of vehicles in the above VIN range. Under exceptional
circumstances this concern could cause the engine to cut out,
although the engine will continue to be driven by the road wheels
through the transmission and drive the ancillaries, so there will be
no loss of power steering, brakes, air conditioning, etc. The engine
should restart without difficulty once the vehicle has come to a
complete standstill.
Action to be taken:
To aid in the identification of repairs required by vehicle, Table
1 of this Service Action provides a breakdown of the repair required
by model year, model description, and VIN range.
For those vehicles that require the ECM to be reprogrammed,
Worldwide Diagnostic System (WDS) release JTP759/31, or later,
should be used.
Model Year Model Description VIN Range Repair Required:
1997 to 1998 XK Series N/A 001036 to 020734 Reprogram ECM
1998 V8 XJ Series (both N/A and SC) 812256 to 819771 Reprogram ECM
1998 XK Series N/A 020735 to 031302 Replace throttle body
1998.75 to 1999 XK Series (SC) 024695 to 042775 Replace TB
1998 V8 XJ Series N/A only 819772 to 853935 Replace throttle body
1998 to 1999 V8 XJ Series SC only 819772 to 878717 Replace TB
Charles_3000
