Engine light went on and reader gave code that lean bank 2.–
TOOTH DOCKER
In reply to a message from TOOTH DOCKER sent Sun 14 Feb 2016:
Without the code that came up, I can’t look up the response.
It may have something to do with O2 sensors. After you
cleared it, did the warning come up again? If not; it may
have been a transient electrical glitch.–
Grahame Loader 98 XK8 Roadster
Calgary, Canada
If you haven’t solved it by now…old message, I know…do a smoke test to look for leaks. My engine codes showed lean banks 1 and 2. My mechanic found several smoke leaks and plugged them. One of the interesting ones was the “o-ring” seal on the oil dipstick! No further problems.
