If you have the later style seats in your XK8 with separate
motorized headrests, and if the headrest(s) is broken, motor runs
but the headrest doesn’t move, I just repaired one per the
instructions in TSB 501-58, my first. It is not a hard fix, and no
parts are needed. I photographed mine and will share, via email,
pics, etc, with anyone requesting it. The TSB estimates 0.4 hours,
I took about 0.75 hours, but played around alot.
On the sore topic of vinyl in the XK8, I was able to completely
inspect the SEAT BACK from the inside. I can verify the only
leather hide is on the seat front face. This includes a total of 4
panels, counting the center pleated section as one. The rest of the
seat back is vinyl. That includes the outer edge, the back, the
back center section and the map pocket on the back of the seat. I
will only comment definitively on what I know, but I suspect the
seat bottom is the same, leather hide on the seat surface, with
vinyl around the sides. It also appears (but not sure) the separate
head rest is leather on the facing side and vinyl around the outer
edge and back.
Why is this important? Leather and vinyl should be treated
differently. Putting an expensive hide food or leather conditioner
on vinyl is not only a wast of money, but you could be shortening
its life. Oils that are made to be absorbed in leather will only
sit on top of vinyl. Not only that, but with sun exposure
(convertibles) the now hot oil is causing surface temperature on
the vinyl surface to be far greater. Traditionally, vinyl is only
cleaned with a very mild soapy water using a dilluted amount of a
mild soap like Woolite (found in the states). Then a protectant for
sun exposure is the best topical to use. I use a product called 303
Aerospace Protectant which offers UV protection. This is not like a
tire dressing or a glaze product. It’s a bit pricey, but worth it.
No affiliation with 303.–
Steve Hannes – 02 XK8 - 96 VDP - 02 X-Type
Phoenix, AZ, United States
