In reply to a message from Barry Graham sent Sat 7 Jun 2008:
I wrote this for another forum a few months ago, and never posted
it:
Rock Meathammer was asking about the interchangeability of Jaguar
V8 engines, as he may have to replace the original unit in his '98
XJ8. This question has been discussed in other forums, so I thought
it best to post the details in a way to make it easy for research.
Any amendments from those who catch an omission are welcome! I did
not endeavor to list every detail, please help with the sketchy
ones if you can. I wrote this from memory, please excuse any
relevant omissions.
This information applies to normally aspirated cars only, U.S.
market cars specifically. Perhaps an S/C engine expert could post a
new thread for those engines as well. We have no 3.2 V8 equipped
cars in the States to my knowledge, so our overseas colleagues may
wish to do the same.
Basic: 1998 XJ8, and 1997-1998 XK8, all are fitted with the AJ26
engine.
Easy identifiers:
Vacuum dashpot on throttle body for cruise control
V V T solenoids mounted on front face of timing cover.
1999 through 2003 XJ8 and XK8 are fitted with the AJ27 engine.
Easy identifiers:
No vacuum dashpot on throttle body (cruise is electronically
controlled)
V V T solenoids protrude up through cam covers at front
Timing cover has blanking plates instead of front mounted solenoids
You can swap any '98 (and '97) AJ26 directly in place of the
original. Change over only whatever accessories you need from the
original unit. Upgrade water pump, thermostat and timing components
at your discretion ( highly recommended).
You can swap any '99 through 2003 AJ27 directly in place of the
original. Most sources will show a change point at 2001: That
signifies the end of the Nikasil lined engine bores, and
commencement of dry cylinder liners. The exact change was at engine
number 00 08 18 XXXX. The number is hard to find, stamped on a boss
at the base of the thermostat housing tower, driver’s side. On 2001
and later engines, the number is stamped on a rib of the engine
block, driver’s side, above the steering rack…again, not very
easy to locate or read.
The most desirable option is to fit an engine after # 01 08 13
0000. This was the commencement, as best as has been documented to
date [credit A. Voss, Belgium from a PUBLIC post], of the multi row
timing chains and third generation tensioners. This engine fitted
to a '99, '00, or early '01 car requires no adaptation and is a
major reliability upgrade. So there’s even more reason to buy the
latest engine you can find and afford.
Note: the V.I.N. number, model year, or built date of the vehicle
are not reliable for identifying these change points. You must
refer to the engine number. The engine number is itself a date and
time stamp: 97 08 17 1130 means 1997 August 17th 11:30 A.M. That
would be an XK8 block in the U.S., we didn’t have XJ’s yet.
…Continued on next post–
All,
I wonder if anyone can help. I good friend of mine is trying to replace
the engine in a 1996 XK8 (which has failed due to the old Nikasil
problem) with an engine salvaged from a 2002 car. Both are UK engines.
Does anyone have any advice on how to carry out this swap? I am sure we
are not the first to try!
Barry
JagtechOhio
