I bought a '98 XK8 2 days ago. Changed the oil yesterday,
and parked it. This morning I went to open the drivers
door, which opened fine (indexed), and then opened the
trunk. The next thing I know, the security light is
flashing red by the Park Selector - and all power has been
disabled. I can even close the doors because they won’t
index (drop down). I must have activated some kind of
Security Death LOCK-DOWN. The driver’s door lock will only
rotate clockwise, but not counter-clockwise - so I can’t
deactivate as instructed by the manual. Does anyone no
what’s going on here. I fear it’s something that can only
be resolved after an expensive tow to the Jag dealer.
Thanks,
1stJagMitch–
1stXK8TX
Thanks,
1stJagMitch
In reply to a message from 1stXK8TX sent Sun 31 Jan 2010:
I think Charles has beaten me
But I feel sure you have a dead Battery
get it Drop Tested first before you spend un needed money–
Bleasie International Cabriolet Register c/o 92hot@aol.com
GRIMSBY, United Kingdom
Thanks for the response folks. I’ll check the battery as
suggested.–
1stJagMitch
Southlake, TExas, United States
In reply to a message from 1stJagMitch sent Mon 1 Feb 2010:
My 99 has been doing the same randomly for the two years I’ve owned
it. Wife was very unhappy camper when we were towed the first time
(’‘I knew you shouldn’t have bought this stupid car’’). Jag dealer
could find nothing but hit me up for a new battery and diagnostic
time. Didn’t solve the problem though. So now I just carry a wrench
and disconnect the battery ground for 10secs. Everything is fine
afterwards and I just have to go through the window game. The only
time it’s a pain is whem it rains.–
user1420
In reply to a message from user1420 sent Mon 1 Feb 2010:
Is it possible that we are married to the same woman? I
have gotten that quote from her for almost every car I have
bought
Doug–
Check if your ground link (directly from battery, in the trunk) is
well attached on car side, and if it is not getting worm when you
switch on the lights with the engine off…
Brdgs,
TC–
In reply to a message from Charles_3000 sent Mon 1 Feb 2010:
TC -
Should the ground wire be warm or cool if the lights are on? I
notice that when I disconnect it from the battery after driving it
is always warm. By the way, this shutdown always occurs (randomly)
only when I shut off the car. I open the driver’s door and the
window won’t go down, so off to the boot to disconnect the battery.
The ground wire will be quite warm. Once the car resets all is fine
for a while until the next random time I turn off the car and it
goes dead.
Mike–
user1420
I spent months trying to solve a similar problem on my '99
coupe and documented the fix here (and elsewhere). It may be
worth checking your car.
I found that the poitive lead connection from the battery to
the two X 250 amp fuses had a slightly loose ringtag
connector. (Although it felt O.K. on a cursory waggle).
I remade the connection using a hammer(!) and then solder
and it’s been fine for the last 4 years.
Suspect my wife must be from your wife’s side of the
family…
Michael–
It depends what you call warm, but it should be as cold as
possible. If it’s getting hot it means that plenty of your good
current is heating the air instead of powering up your car’s
equipements… Given your symptoms, I’d replace that wire asap.
Brdgs,
TC–
Hi in any electrical system cars or otherwise
Cables should not get warm, usualy a sign of a loose
connection eventualy it will burn out.
You would not expect for example the lead on your kettle or
electric drill to get warm.–
In reply to a message from Bleasie sent Tue 2 Feb 2010:
Last night I pulled the suspect battery and took it to the auto
parts store, where they ran a combination 45 mintue test/charge.
At the end the battery was declared ‘‘GOOD.’’ I re-installed
and ‘‘all systems are go’’ - for now. I’m now concerned about the
longevity of the fix as commented by others in this thread. So I’ll
keep a close eye on it. But I really appreciate the feedback and
assistance from Bleasie and others. The Jag fraternity is good
bunch of guys! Safe Driving - until next time…
-Mitch–
1stJagMitch
In reply to a message from 1stJagMitch sent Tue 2 Feb 2010:
Thanks for the advice. I’ll check the cables (both + and -) this
spring when the cover comes off and the birds sing…
Mike–
1999 XK8 Conv
