I have a 2003 XKR and in low gear and reverse it shunts when
pulling away.
Any ideas?
Someone mentioned to change the engine mounts?–
DarrenXKR
In reply to a message from Skinhead nut sent Sun 1 Apr 2012:
It could be a fluid level problem. Any sign of leaks? The
hoses from the transmission to the cooler can chafe.
Checking the level itself is not so easy unfortunately as
you need the engine running and need to fill it quickly
before it reaches about 50 degrees. To make life more
difficult the exhaust is in the way of the filler plug.
Regards
John–
There is quite a lot of info in posts on the S type forum
and if you google ‘‘The lunge’’.It may help you ,I didn t take
much notice as I had a different problem.–
