Hi all,
Will a ZF4HP24 auto trans out of a 4 liter XK40 with the AJ16 engine fit to the older XK6 engine?
Are there any conversion kits available. Thanks in advance
Hi all,
Not without a lot of work, the AJ6 engine is tilted over 15 (?) degrees so you would need to fabricate a sandwich plate also the 4HP24 is the electronic version which uses inputs from various sensors on the engine.
The mechanical version is the 4HP22.
Thanks Robin, Same question this time for the 4HP22 ?
I think Graham Whitehouse Transmissions in the UK modify 4HP gearboxes to fit the XK 6 and V12. Another company called Motor Legends has been working on fitting the 6HP to the old engines. Both cost, especially the latter.
