I dont have a whole lot of knowledge about it myself so I copy and pasted this from Wikipedia.
The LL8 (or Vortec 4200), is a straight-6 gasoline engine produced between 2002 and 2009. It was the first Atlas engine, and was introduced in 2002 for the Chevrolet TrailBlazer, GMC Envoy, and Oldsmobile Bravada, the engine is also in use in the Buick Rainier, Saab 9-7X, and the Isuzu Ascender.
It displaces 4.2 L; 253.9 cu in (4,160 cc), with a 93 mm × 102 mm (3.66 in × 4.02 in) bore and stroke. It has four valves per cylinder, utilizes dual-overhead cams (DOHC) design, and features variable valve timing on the exhaust cam, a first for GM Inline engines. When introduced, this engine’s power was 270 hp (201 kW) at 6000 rpm and torque was 275 lb⋅ft (373 N⋅m) at 3600 rpm. 2003 saw a slight bump in power to 275 hp (205 kW), while torque was unchanged. For 2006, power was increased to 291 hp (217 kW) at 6000 rpm and torque to 277 lb⋅ft (376 N⋅m)) at 4800 rpm with the addition of a MAF and a complete internal redesign of the engine; however due to the new SAE rating procedures ratings can vary slightly between years. Engine redline is 6300 rpm.
The LL8 was on the Ward’s 10 Best Engines list for 2002 through 2005 and was the basis for all the other Atlas engines. With the closing of the Moraine, Ohio plant and the termination of the GMT360 platform (Chevrolet TrailBlazer, GMC Envoy, etc.) the production of the LL8 was also terminated.
