HOW DO I REMOVE THE WOOD TRIM AROUND THE WINDOWS.
THERE ARE NO SCREWS HOLDING IT AS ON A Mk 2
The wood trim simply clips in…but if you car is like mine, someone had glued them into place.
Jeff S.
Atlanta,GA
74’etype
57’ Mk1
Hi Jeff
Thanks for the reply and I think you are right someone has glued mine also.
They look bad now as I have re polished the dash wood, they looked OK before.
I will try very slowly to pry them out, Can you remember the rough location of the clips?
Thanks again Joe
Joe,
At each top corner there is a clip…Once the top unclips, you should be able to pull straight up. Hope this helps…JS
