Hello everyone, I hope you are all doing great. Once again, I am seeking advice.
In my last post, I had issues with boiling coolant, but since the temperature gauge showed temps below 100 degrees, I assumed it must have been the expansion that caused it to spill after being too full.
Last week, I took it for a ride again, and after 30 minutes or so, I had a hard time shifting gears. They would not go in on the first 3-4 attempts, and it required quite some force, which was very stressful in that day’s traffic. Reverse would work, but it always made a scratching sound as if the clutch was not fully engaged, even though I was stepping on the clutch pedal fully. I made it to a parking lot, and again, the coolant was boiling and spilling out.
Fast forward, I brought it to a garage, and apparently, the belt of the cooling system did not run properly, causing the overheating. That was fixed, and they bled the clutch.
When I drove home, the gears shifted very smoothly, in fact, smoother than the first day I got it. However, after just 10 minutes of driving, I again had boiling coolant, and I noticed something new. I cannot say for sure if I experienced this already when the shift issue started, but I might have.
When I removed my foot from the gas pedal, the car slowed down noticeably faster than before. It almost feels as if the handbrake was engaged, or as if I was stepping on the brakes a bit.
Does anyone have a clue about what’s likely to be the issue here? I am quite concerned that it might be an issue with the engine. All of my budget went into the nuts and bolts restoration, including a complete engine overhaul, but the garage that did that is 1000km away, so it’s difficult to consult them directly.
On a side note: one of the carbs cap was off when i got home (not sure if the garage opened it or whether it came undone on its own, not sure thats relevant).
Thanks!
