I spent the last few weeks wrapping up the fuel system. It consists of the following:
20 gallon flat bottom fuel cell with -8AN rollover valve vented under the trunk floor
-8AN feed to coarse prefilter
-10AN feed to 400lph pump
-8AN feed to C5 FPR
-8AN return to top of fuel cell
-6AN feed under the car to fuel rail
-Flex sensor plumbed inline with feed
I filled the cell with about 7 gallons of fresh 93 pump just to check for leaks and found none (on the pump suction side, at least). I need to run the pump manually to prime the system and see if there are any leaks on the pressure side of the pump. Also installed the Lowdoller fuel pressure sensor on the rail after taking out the Schrader valve to be able to see if the pump can keep up.
While I am waiting on some AN fittings I decided to jump into the Terminator X install. It’s mostly plug and play, just a matter of routing things neatly in the engine bay to prevent damage from heat and moving parts. That being said there are some loose wires to connect which I saved for last. I hate wiring, it usually means uncomfortable positions.
The ECU will live in the glovebox. It’s very compact so there will still be room for documents, etc. My goal is to leave the interior looking as stock as possible. There will be no modifications except to the gauge cluster.
I have a new fuel gauge that uses the correct 0-90ohm resistance range compatible with the sender in the fuel cell, and the tach will be driven via the output on the TermX. I would like to use the stock speedo by driving it with a configured output from the ECU but haven’t really looked into the details yet.
The interior is a bit of a mess at the moment but will go back together once I run the fuel pump trigger wire and the sender signal wire to the trunk.
Last but not least - check out that front ride height!
It settled in quite a bit due to a couple of reasons:
-Removed 15 gallons of fuel from the stock tanks, which transferred weight to the front
-Jumped up and down on the front bumper to “settle” the springs which was good for another half inch or so
-Added all the accessories under the hood like the engine harness, fan harness, and fluids (engine oil, coolant, power steering), and battery.
Keep in mind this is stock springs (uncut to preserve ride quality), 2x spring packers removed (you may have seen them in the trunk), and 3/4" spring pan drop.
Hoping to have the first startup next week!
