Saga continues on my Uncle’s XJS. Now that the car is running I have noticed the car pulls hard left upon braking. The right front calliper pistons would not retract with the bleeder open. Ordered pads, rotors, calipers, and dust seals knowing this was not the issue. Have no flow of brake fluid from the RHS brake line. Undid the line from the master, blew out the line no issues. Took the solenoid valve block off the master. Disassembled the block, tested the solenoids all but 2 are opening. The windings on the two not working are intact, the solenoid will not open. Phoned around a bunch of spots today with no luck. The solenoids I need are the two outer closest to the connector. If anyone would be willing to part with, or could possibly tell me where to source these solenoids or a pack it would be much appreciated.
Bears
