I don’t use my Jag as often as I should so it had become a little dusty, and I decided to wash it.
The driveway has quite a slope, so I tend to let the car roll out of the garage and on to the driveway with the ignition on and the transmission set in ‘N’, that way I only start the engine once and I reason that it would also make it obvious if the brakes are binding since the car not has not been driven for a few weeks.
On backing the car out, I noticed there was a noticeable patch of ATF on the garage floor. This concerned me, since the transmission has always been leak free. I had a look under the car; as far as I could tell the leak was probably coming from the gasket, but may have been from above it. I couldn’t really tell.
I checked the transmission fluid level, expecting it to be normal - the quantity of fluid on the garage floor was noticeable rather than great.
To my surprise it now reads drastically high - nearly 2 centimetres above the white plastic part. I haven’t changed the fluid recently and I have not added any.
I started the engine and it caught with a wobble through the car and ran roughly. The transmission made a frothing sound - and the car was reluctant to move forward. I shut the engine down immediately, so as not to do any (more) damage. It now stands stricken on my drive! Naturally, it has fallen in the part of the drive most difficult to move it from!
What sort of problem does this sound like? - I assume that the fluid level is very high because a good quantity of it has drained out from the torque converter? I check the level reasonably regularly, pre-incident and it was as far as I am aware, correct.
Has the torque converter failed? - Or does these symptoms point to another problem?
The last time I drove it, the car performed normally. It has long taken up drive with a slight ‘thump’ occasionally - but it idles slightly high. The idle was raised slightly by a Jaguar dealer in the mid 1990s to cure a tendency to stall.
The car has also had a slight shudder, also intermittent, for quite a long time. I suspected the transmission, but when shuddering slightly the shudder didn’t stop if the car was put into neutral, so perhaps wrongly, I blamed some other and as yet undiscovered cause!
Also, I shut the car down very quickly so as not to cause any more damage. Would running the car cause or risk further transmission damage? - I ask because the car isn’t in an easy to access place for when the tow truck comes and I might be able to limp it back into the garage, but don’t dare to!
And just when I was saying how reliable the old beast is!
