myengine light just popped on after driving for about 2 hours - Jag manual says contact jag dealer - anyone have any clues i can check ?
Rose,
Your car is 2 generations newer than any of the Series I, II, and III XJ6 or XJ12 cars discussed on this list. You need to be on the X300 list.
Ok Thank you i appreciate
I moved you to the X300 list.
Firstly use.a Scanner/Reader to check for codes and let the list know what they are.
I have a code reader and will test -
P1179 bank 2 sensor 1 ? itβs an in line 6 - Oxygen sensor
how many are there & where do I get & how to replace
