Thanks all for your replies, but unfortunately, none of that information has progressed my dilemma.
I probably have a better measuring facility than most, is not all, differential repair services, in that I have a Coordinate Measuring Machine (CMM), with a measuring increment of 0.0001mm (0.00000394"), housed in a temperature controlled room.
The measurement was taken by setting the differential housing vertically on the granite table of the CMM, sitting on a parallel faced, hollow boss to clear the end of the pinion shaft, with the boss locating on the machined step for the Pinion Seal. The top face, where the rear cover interfaces was checked for being parallel with the table; it checked out to be parallel within a small tolerance.
As an added step to ensure that any out of square with the table didn’t introduce any measuring error, small as it may be, three points on all four faces that represent the centre line of the Crown Wheel were probed and the CMM aligned via its software to be on the same plane as the four faces. A measurement was then taken down to the ground face of the Pinion Shaft end. Accordingly, my measurement of 72.63 is very accurate.
The only “B” dimension that would work with my 72.63mm dimension is the 2.968" “B” value of the 5HA, but then dimension “D” is not the same. Dimension “D” of the diff I’m working on is the same as the 4HA. Using the 5HA dimension “B” would result in a circa 3mm shim stack which would not allow the Crown Wheel assembly to assemble with the diff housing and Pinion. This diff is out of an XJS and shows none of the hallmarks of ever being apart after initial assembly.
As I’ve stated in earlier Posts, the 66.67mm “B” dimension will not work, for it would result is a shim stack height of over 6mm for under the Pinion inner bearing cup. If such a shim stack were to be used, it would be impossible to assemble the Crown Wheel assembly with the diff housing and Pinion.
From the picture in my first Post of the 3.31 and 2.88 Pinion Shafts, it can be clearly seen that the thickness of the 2.88 Pinion Gear is thinner than that of the 3.31 shaft. The overall length of the two shafts is the same, meaning that the difference in thickness of the Pinion Gears is via more material being removed (circa 6mm) during manufacture, from the face of the Pinion Gear where the inner bearing seats. It would make Zero sense to remove this material, only to add it back via a circa 6mm stack of shims.
Bill
