all fuses are good but my Navigation screen doesn’t even come on, i was wondering what is the most likely cause before i try troubleshooting
I don’t believe the nav feature is being supported any longer.
i dont really need the GPS/Nav but was wondering if anyone knew what would cause the screen to not light up anymore
Check your interior wiring harnesses for wear or moisture around the passenger seat and floor.
Your module may also be out, and, check settings. A code may tell you if the certain module is out.
Bob
ok thanks!
i just noticed a wire in the trunk thats not connected coming from front of car, the module does load and unload the old dvd, but maybe that wire needs to beconnected to module?
