Is a 1998 XJR differential a direct swap into a 1998 Daimler Super V8? I have been offered one but heard somewhere that the ratios were different. Sounds odd, as I had always thought the XJR and Super V8 had identical running gear.
Pity you’re in the UK. I’m trying to get rid of this new old stock one for less than the postage would cost. I keep trying to list on ebay but it insists on GBP instead of USD for local pick-up
Are you clearing out the garage?
I am currently waiting for an output shaft for my differential. When I receive that, we’ll see if the differential is repairable. Pinion and right hand output shaft were leaking. The bearing on the output shaft has become very hot. And there was not a lot of oil left in the differential.
I could do with a backup plan. But I guess the super v8 differential won’t fit my manual 3.2l.
Ouch. I was looking for used ones here in Germany. Nothing below 500.
I am still waiting for the output shaft to arrive, it has been stuck in customs for 3 weeks now…
This is slightly annoying, as I can’t get the car on the ground without the output shaft.
