Hi Gang,
Can anyone tell me if the 4.0 L engine has Variable Valve Timing?
Also does the 4.0 L engine run hydraulic lifters?
Thank you!
Solo Out…
Hi Gang,
Thank you!
Solo Out…
No, as to Variable Valve Timing. IIRC, Jag didn’t come out with that feature until the XJ8s (“X-350”?) came along. It also, BION, has mechanical lifters, hence why the lash should be adjusted on them every ____ miles (I forgot the recommended interval ). I really don’t know why Jag did not favor hydraulic lifters (anyone? ). Heck, I remember the 1.9 liter straight 4-cyl. engine in my '72 Opel (GT) used them. But then, it also had that nifty “cam in head” design, too.
