Getting to know my S3 and noticed in the passenger footwell a disk attached to the forward wall.
Still scratching my head….
It’s the footwell fresh air ventilation system. The complete system should have “Pull air” control levers on the A posts to control the arflow from the picture frame triangular collector boxes. The comes to those from the air dams either side of the bonnet grille.
kind regards
Marek
Marek gave you the correct answer.
I am restoring my Series III and have it in pieces – this photo may help visualize that vent and other stuff hear it
Here are the scoops - at 10 o’clock and 2 o’clock hanging off of the picture frame - see the three washers sitting on the left hand scoop grille.
and here is the control mechanism - it’s a bicycle brake cable
Between the scoop and the firewall hole is a 2" flexi hose which was also used on the XJS aircon.
kind regards
Marek
Sure some nice cars good job Merek
This is all very helpful guys. thanks!. And Marek, where did you have your engine rebuild done. I’m considering doing something like this in the winter and looking for potential providers. Unfortunately, I don’t have the skills and would like to upgrade the engine and gearbox to 5 speed. Also, what is the black box just under the RH hood latch pull?
Except for a bit of welding, I did it all myself. I am in the UK, so you will have to look for someone more local in any case.
The black box is an Inertia switch from an XJS. The car is fuel injected, so it has a cut-off in case of an accident.
There is plenty of advice already posted about 5speeds. A Jag box with a compact type-A overdrive is a drop in replacement.
kind regards
Marek
