I’m having trouble cross referencing the inner shaft bushings for the rear lower control arm. CAC4713 is most commonly referred to as 95-97 but does it go back to 88 or some other year?
Or any aftermarket bushing part # specific to 93 to 88 stamped steel control arms?
Thanks to Larry, I now see this diagram:
https://parts.jaguarlandroverclassic.com/parts/index/part/id/C01.918.91857.91857287.918572874861/brand/jaguar/
It shows CAC77601 in the upper location. Good. Found those everywhere.
It shows CAC4713 in the lower location (the location I’m interested in) but only FROM VIN 696460 (I am VIN 671XXX) Which is the start of the newer cast arm for the 94 40’s and the 300’s per bulletin H11.
Obviously the OD would be the same for both numbers, same pendulum.
Probably same ID if same pendulum bolt.
Variable is probably length or something else about the inner sleeve for mating to the cast arm.
So, which number to use for the stamped arm?
