Hi
The ABS light on my 1990 XJ40 Sovereign is coming on intermittently, it can stay on for full journeys for days, then it suddenly goes off, however I am finding it is on more than it is off.
I do not have any issues with brake performance.
Hi
Plenty of posts in the archive regarding re-flowing the solder joints in the ABS module in the boot/trunk
Also, make sure the pickup sensors at the wheels are clean and with good connections.
David …
My priority of troubleshooting this would be …
ABS overvoltage relay … Check that the relay opens and closes. Also check that when the relay is closed that it actually does have continuity through the load side.
ABS wheel sensors … Check for continuity and condition.
ABS electronic control unit … Replace. Lots of used units online for under $50.
