Hi, all…
My linkage is sticking a bit when I’m cruising and then take my foot off the gas to decelerate. It will maintain engine speed until I push the clutch in again and give the gas pedal a quick hit ( like you might do if the car was idling too fast ) … and then the car decelerates as normal.
Otherwise, engine runs like a champ. Properly tuned.
I just had the carbs rebuilt…have properly attached the carbs to the intake manifold and made sure all connections were properly tightened / aligned / working.
Is there some kind of lubricant that might help here…or do I need to just carefully recheck all the connections/movements while someone works the gas pedal, etc…or all of the above.
Thanks,
Harold
1965 XKE 4.2L OTS
