S1.5 OTS. Wondering if there are any alternatives to continuing to replace the sticking reaction valve in my master cylinder, which I’ve now done twice. Brand new parts, usual sources.
Symptoms probably familiar to some/many - city traffic, lots of stop/go with (very) gentle prods of the brake pedal, pedal gets higher and harder until it begins to take a few seconds to release, but in my case it gets to the point where it won’t release at all.
And always at a busy stop light, usually a left turn (in US) with a line of traffic behind me, for maximum embarrassment.
I fitted a cheeky little release valve whereby I can manually bleed the vacuum from inside the cockpit, and that mostly mitigates the issue quite well, but yesterday it got to the point where even at “full bleed” it couldn’t release it quick enough and I had to pull out of the line of traffic was in and hide behind a bush - one I’ve used before for the same purpose - while I switched off and sat there for 15 minutes (!) until it finally let go.
Happily I was only 200 yards from my house and I managed to get it home, although forcibly driving it over the brakes after about half way, until I stopped it again in my gate - to the great amusement of my neighbours.
As well as the scenario above it’s also begun to happen at freeway speeds, gently braking - I always brake gently now! - to shed some speed before letting off to continue, say dropping from 70 - 50. Initially you don’t notice the drag because of the momentum of the car, but then after a few seconds the car noticeably lightens up.
At this point it’s practically undrivable for anything but the shortest distances, and my kid is 8 next week and so (in CA) is allowed to ride in the front seat and he’s begging me to pick him from school in it. Which I can’t, because it will lock up in the pickup line, and while everyone else is laughing at me he will be crying.
All I’m getting from the usual suppliers is that yes, they are seeing problems with the part overall.
There is talk of fitting a beefier spring (thoughts?) but I’m also wondering if anyone has found a part from a.n.other vehicle that fits, and works?
