I am interested in a pair of your half-moon seals and, if you are still making it/it fits (didn’t notice an update to post 28), one chain tensioner plug. These are for my 1972 Series III E-Type V12 engine.
Yes they are available. I had few customers that fitted them to aj6. I’ll try to find pictures.
Try searching online parts catalogue https://parts.jaguarlandroverclassic.com/
If it has half-moon seals part number: C30431 then they will fit
Hi John, recently purchased a '91 XJS V12 and mechanic advised me to replace the valve cover gasket. I’m interested in a set of your aluminum half moon seals. Please let me know how to purchase, can be reached at mattyhilt87@gmail.com, or 480-332-6084.
And if you haven’t done so yet, this would be good time to replace the oil feed banjo bolts at the back of the engine. And the timing chain damper release hole cover at the front of the engine. If I remember correctly John John has machined all these pieces.
Hi - do you still do the half moon seals, chain tensioner plug, SS oil feed banjo bolts and radiator bleed pipe banjo bolts for the V12 - I have an 86 XJSC I and cleaning up.
