hi all, my automatic door locks have stopped working when you move off. any ideas on where to look to fix. thanks.
I’m thinking it’s probably tied into the transmission select system some way … When the car is put into reverse they lock … (?)
when I had this symptom it turned out to be the linear switch adjustment on the side of the gear lever
How old is your battery? When my battery is nearing its useful life…that’s the first thing that goes.
The other solution I have is to unplug and then plug back in your lock relay.
hi, battery near new. where is the relay? thanks.
They’ve got the infor you need
