Hello Tony,
So, you are from Australia. I’ve never been there. I know it is beautiful, possibly one day I’ll get there.
A couple of questions: Will you advise me as to what a valve train is? I would not know how to pump out whatever I flood the valves with; will you kindly advise? With your tool for the water pump, am I to assume that what goes through the unthreaded holes would the bolts coming out of the water pump? And, that they would be screwed back into the water pump? Then screw the middle bolt in toward the pump so that the pully will be drawn away from the engine…yes?
I appreciate your help. I just wish there was a chemical that I could use in the crankcase to possibly dissolve whatever is caked up inside the plugs you mention. As for my vehicle, it is a 69 Jaguar, XKE Roadster.
Please advise…have a great day.
James Joseph
May 10
haditall:
Is there a solution I can use to dissolve was may be present? You had mentioned “Plugs” in the crankshaft. I’m not really sure what that would consist of. I wouldn’t think it would be the same substance that would be in the water system. I’m thinking sludge…perhaps? Also, Tony, your tool for the pully, are the holds threaded? And, I am thinking that the center hole would be threaded to receive the nut you mentioned. I’m not sure what side of the plate the nut would go one…I’m thinking the side closest to the pump. Perhaps both sides? One on the outside to stableize the bolt. Speaking of bolts, what size bolts did you use?
from Ozstralia maaate! (see the little flags…put in your country on profile, displays yr national flag)
the crankshaft sludge is a build up of oil sludge & grit that can become solidified, and occurs on all these motors, the crankshaft has about 6 large threaded plugs, which need a machine shop to remove, clean out the inside crankshaft, fit new plugs.
if these are blocked up with sludge, it can take out a bearing
advise you to check about this by searching in the top corner where the magnifying glass is !
at the end of the day, if something goes wrong, you will need an engine rebuild.
If you take it apart now, you will probably still be needing a rebuild,
so looking at it that way, you dont have much risk on the downside by having a try.
…its just that “best practice” thing…
the WP plate has 4 unthreaded holes matching the threaded ones in the pulley
the middle hole has a nut welded on, I just screw the bolt in, or use some washers, and it will press the pulley off the shaft from the outside.
I make one for any vehicle that has threaded holes, method in the FSM likely distort the pulley
I would also flood the valve train with oil, (valves can be stuck), and pre-oil the oil galleries with a pump, drain off all the excess b4 rotating engine
imo the E-type list will be good for you (if you have an E-type?)
You should introduce yourself on that list, if you havent already
