I’m now at the point of fitting the sills to the chassis, then aligning the front end to the sills before fitting the doors. I have some questions about the packing spacers, prompted by my findings when I dismantled the car. I’d be grateful for comments on the following:
- The small rectangular plates that support the base of the bulkhead on the inner edge of the main chassis rails, i.e. the bottom of the toeboard. They fit through an oval hole to allow some sideways adjustment. Viart (p.336) implies that there should be only one of these - my car had 3 on one side, and 5 on the other.
- Is the distribution of spacers shown on Viart p.336 typical, give or take? I have some with no aluminium spacers. Should there be fibre between chassis and aluminium spacer, or fibre between spacer and body? Both, or just one or the other? I’m assuming one aluminium spacer with one fibre spacer on top of it.
- Should the sill (and other) bolts be positioned with the bolt head down, or on top? My car still has the original Philidas locking nuts as per early 140 (April '55).
Given that I’m replacing so much metalwork, I’m assuming I should start with Viart’s suggestions and add/subtract accordingly. How close to his distribution of spacers do people normally get, or is it very variable? Interestingly the Coventry Autos spacer pack aluminium spacers are all different thicknesses from my originals (e.g. ½" instead of 7/16" etc.)
Thanks
Roger
